INSTALL BADGER FLIX APP
Follow all on screen prompts to set up your device, connect to your wifi, the Firestick may do updates. Once completed it will ask you to link to your Amazon account, follow the on screen prompts for this until you get to the Firestick Home Screen.
Now, you need to enable a setting in the firestick or cube settings.
On the Firestick home screen -> SETTINGS -> MY FIRE TV -> DEVELOPER OPTIONS and enable APPS FROM UNKNOWN SOURCES.
*** If you are using a 3rd generation device (newest), you won’t be able to enable this setting until prompted on the screen.
You must also have the app 'downloader' .. if you don't have this app already, go to 'Find' search for 'Downloader' and 'get' the app
enter 'androidbuzz.ca/flix' in URL field & click go
*** If you get a pop up to enable installing app, please enable it
Connect to your Wifi in your Settings
Now, go to your home screen
open 'Chrome' app - if you don't see Chrome look for 'Browser' (may not be on Home Screen, may be in Apps)
(if you don't see it, go to apps and open file browser/file manager/file explorer and navigate to the downloads folder on your android box .. open the badgerflix.apk and click to install)
(if you don't see open, navigate to the 'Badger Flix' app in your apps)
Once Badger Flix is open, it will ask you to login
Enter any name of your choice into the 'Any Name' field
Enter the Username & Password you were given for your LIVE TV subscription
Click Login
If you get an error, go back and double check the spelling of username and password (these are case sensitive)
That's it .. start watching!
