**** IMPORTANT ****
This app requires a keyboard or remote - a mouse will NOT work with this app.
**** IMPORTANT ****
INSTALL BADGER APP
Follow all on screen prompts to set up your device, connect to your wifi, the Firestick may do updates. Once completed it will ask you to link to your Amazon account, follow the on screen prompts for this until you get to the Firestick Home Screen.
Now, you need to enable a setting in the firestick or cube settings.
On the Firestick home screen -> SETTINGS -> MY FIRE TV -> DEVELOPER OPTIONS and enable APPS FROM UNKNOWN SOURCES.
*** If you are using a 3rd generation device (newest), you won’t be able to enable this setting until prompted on the screen.
You must also have the app 'downloader' .. if you don't have this app already, go to 'Find' search for 'Downloader' and 'get' the app
enter 'tv.androidbuzz.ca' in URL field & click go
*** If you get a pop up to enable installing app, please enable it
Connect to your Wifi in your Settings
Now, go to your home screen
open 'Chrome' app - if you don't see Chrome look for 'Browser' (may not be on Home Screen, may be in Apps)
(if you don't see it, go to apps and open file browser/file manager/file explorer and navigate to the downloads folder on your android box .. open the badger.apk and click to install)
(if you don't see open, navigate to the 'Badger' app in your apps)
Once Badger is open click 'Settings'
Select TV Guide
Enable 'Update on app start'
Enable 'Update on playlists change'
Press your back button twice until you get to the home screen of Badger
Select login
Enter anything you want to call this device into 'any name' (ie; living room, bedroom, tv, your name, etc)
When you are prompted for Username & Password .. use the info you were supplied with.
Uncheck the 'Include VOD'
Click Next
If you get an error, go back and double check the spelling of username and password (these are case sensitive)
Once it says 'Playlist is processed' click Done
You TV guide will default to the first channel in the list, to change press the left arrow on your remote and highlight whichever category by moving up or down to it. Once you have it highlighted, press the right arrow and find your favorite channel.
Press 'ok' to preview the channel, press 'ok' again to make full screen'
