Many more exiting features in new Focus Responsive Version by WallBB. Download Today.
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Using the app
#1
Access the EPG (guide)
To access, or bring up, the guide press the back button on your remote.  This will bring you all the channels in the current category you are viewing.  If this is your first time the default category is All Channels, this may take a few seconds to populate.
_____________________________
Adding or Removing Channel to/from Favorites
Find the channel you are looking to add/remove, highlight it using your up/down arrows.  Once you have the right channel selected, press and hold your 'ok' button on your remote (usually big center button).  This will pop up a side bar on the right hand side.  The middle icon should be a star, click this icon.  If it is not already a favorite, it will say add to favorites, if it is already a favorites this will say remove from favorites.  Click it to change the status of this channel.
Changing Categories
If you want to view just one specific category, whether its Canada, USA, NHL, etc, press the left arrow on your remote while viewing the guide.  This will bring up a list of all available categories to select.
Hide/Remove Channel Categories
By hiding categories you are not using, it will load your channels and guide faster, and it will make finding the channels you actually watch a lot easier.  To do this, go to your channel categories screen as mentioned above.  While any category is selected, press and hold the 'ok' button on your remote.  This will populate a different side bar menu.  Navigate down to 'manage groups' and select it.  Any category with a blue bar/dot beside it is what you will see, to hide one go down to that category and press ok on it to side the blue bar off.  This will hide that category.
In here you can also sort the categories alphabetically (easier to find for most) or any other way you'd like.
Reply
Forum Jump:
Users browsing this thread: 1 Guest(s)
About The Android Guys (TAG) Help
Focus MyBB Theme is designed for MyBB 1.8 series and is tested properly till the most current version of MyBB i.e. 1.8.x. It is simple, clean and light MyBB theme with use of font-awesome icons and shrinking header.
Modify above message at Admin CP -> Templates and Styles -> Focus Templates -> Footer Template - footer
              User Links
