Many more exiting features in new Focus Responsive Version by WallBB. Download Today.
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Installation
#1
INSTALL BADGER DYNASTY
Follow all on screen prompts to set up your device, connect to your wifi, the Firestick may do updates.  Once completed it will ask you to link to your Amazon account, follow the on screen prompts for this until you get to the Firestick Home Screen.
Now, you need to enable a setting in the firestick or cube settings.
On the Firestick home screen -> SETTINGS -> MY FIRE TV -> DEVELOPER OPTIONS and enable APPS FROM UNKNOWN SOURCES.
*** If you are using a 3rd generation device (newest), you won’t be able to enable this setting until prompted on the screen.
You must also have the app 'downloader' .. if you don't have this app already, go to 'Find' search for 'Downloader' and 'get' the app
enter  'androidbuzz.ca/dynasty' in URL field & click go
*** If you get a pop up to enable installing app, please enable it
Connect to your Wifi in your Settings
Now, go to your home screen
open 'Chrome' app - if you don't see Chrome look for 'Browser' (may not be on Home Screen, may be in Apps)
(if you don't see it, go to apps and open file browser/file manager/file explorer and navigate to the downloads folder on your android box .. open the Badger-Dynasty.apk and click to install)
(if you don't see open, navigate to the 'Badger Dynasty' app in your apps)
Enter anything you want to call this device into 'any name' (ie; living room, bedroom, tv, your name, etc)
When you are prompted for Username & Password .. use the info you were supplied with.
Click Add User
If you get an error, go back and double check the spelling of username and password (these are case sensitive)
After you log in, it will bring you to a 'List Users' screen - click on the account you just created.
The app will now 'Update' by downloading all the information for movies, tv shows and 24/7.
Once finished you will be brought to the home screen.
** OPTIONAL ** This app defaults to open up automatically when you turn on your device, to disable this go to settings -> general settings -> uncheck 'auto start on bootup' and scroll to the bottom and click save.
You can now start watching TV.  Select whatever you are looking for and start watching!
Reply
Forum Jump:
Users browsing this thread: 1 Guest(s)
About The Android Guys (TAG) Help
Focus MyBB Theme is designed for MyBB 1.8 series and is tested properly till the most current version of MyBB i.e. 1.8.x. It is simple, clean and light MyBB theme with use of font-awesome icons and shrinking header.
Modify above message at Admin CP -> Templates and Styles -> Focus Templates -> Footer Template - footer
              User Links
