Many more exiting features in new Focus Responsive Version by WallBB. Download Today.
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Installation
#1
    INSTALL Badger-VOD APP
enterĀ  'androidbuzz.ca/apps/Badger-VOD.apk' in URL field & click go
open 'Chrome' app
enter 'androidbuzz.ca/apps/Badger-VOD.apk'
(if you don't see it, go to apps and open file browser/file manager/file explorer and navigate to the downloads folder on your android box .. open the Badger-VOD.apk and click to install)
(if you don't see open, navigate to the 'Badger VOD' app in your apps)
When you are prompted for Username & Password .. use the info you were supplied with.
Click Login
If you get an error, go back and double check the spelling of server, username and password
It will Download the Movies and Series, once completed it will take you to the home screen
Now start watching TV
Attached Files Thumbnail(s)
Reply
Forum Jump:
Users browsing this thread: 1 Guest(s)
About The Android Guys (TAG) Help
Focus MyBB Theme is designed for MyBB 1.8 series and is tested properly till the most current version of MyBB i.e. 1.8.x. It is simple, clean and light MyBB theme with use of font-awesome icons and shrinking header.
Modify above message at Admin CP -> Templates and Styles -> Focus Templates -> Footer Template - footer
              User Links
