Many more exiting features in new Focus Responsive Version by WallBB. Download Today.
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Installation
#1
INSTALL BADGER LTQ APP
enter  'androidbuzz.ca/apps/Badger-LTQ.apk' in URL field & click go
open 'Chrome' app
(if you don't see it, go to apps and open file browser/file manager/file explorer and navigate to the downloads folder on your android box .. open the Badger-LTQ.apk and click to install)
(if you don't see open, navigate to the 'Badger LTQ' app in your apps)
When you are prompted for Email Address & Password .. use the info you were supplied with.
(Enter your Username into the 'Email Address' field)
Click Remember Me
Click Login
If you get an error, go back and double check the spelling of server, username and password
Once you login, you will be taken to the home screen and the app will load the data.. this will take a few seconds and then the home screen will load the info.
Now start watching TV
Reply
Forum Jump:
Users browsing this thread: 2 Guest(s)
About The Android Guys (TAG) Help
Focus MyBB Theme is designed for MyBB 1.8 series and is tested properly till the most current version of MyBB i.e. 1.8.x. It is simple, clean and light MyBB theme with use of font-awesome icons and shrinking header.
Modify above message at Admin CP -> Templates and Styles -> Focus Templates -> Footer Template - footer
              User Links
